8 | |
6 | |
4 | |
3 | |
2 |
The title says it all - I'd like to have the option to inherit my configuration settings from the previous LabVIEW installation (or from a specified path). Currently I have to do this manually by copying the ini file from the previous version, but I'm never sure whether there will be compatibility issues with the new version of LabVIEW or if there are obsolete settings. The installer should check for compatibility/obsolescence issues as it creates the new ini file.
Alternatively / additionally, I'd like to be able to specify where LabVIEW loads the LabVIEW.ini file from (which could be located on a network or USB disk).
