10 | |
3 | |
2 | |
2 | |
2 |
I initially came here to suggest that there should be an exclusion added for error terminals when selecting the option in Tools > Options... > Front Panel. But then I thought, why not just let us configure which data types default to required and which default to recommended. I'm probably being nit picky here, but I think this would be a really cool thing to add.
Check the box, then a nested list underneath, where you can add exclusions, becomes un-grayed out. Data types you don't want to default to required.
Saying "Thanks that fixed it" or "Thanks that answers my question" and not giving a Kudo or Marked Solution, is like telling your waiter they did a great job and not leaving a tip. Please, tip your waiters.
