I found this idea:
https://forums.ni.com/t5/LabVIEW-Idea-Exchange/Improve-the-file-dialog-default-path-when-saving-new-... (I can't make links in Chrome for some reason...)
but wondered if just adding a button that would take you to your last active project's directory would simplify things. In the below image, I just over-wrote the "Make New LLB" button, but a fourth button would be fine by me, too.
