 rolfk
			rolfk
		 on
		10-03-2011
		02:06 AM
			7 Comments (7 New)
			 on
		10-03-2011
		02:06 AM
			7 Comments (7 New)
		The very first time that you save a new project, the file dialog defaults to the My Documents directory (on Windows; similar on other platforms). While it is sometimes a good idea to put all the user docuements in the My Documents folder, my company uses a different approach where the currently active projects are in a distinctive folder on a seperate encrypted volume. It would be nice if we could set the configuration file of LabVIEW to start there instead of in MyDocuments. For all other file types, when you save them for the first time, ... ... if you are working outside of a project, the file dialog would also default to the specified location. ... if you ware working inside of a project, the file dialog would default to the directory where the project file is saved. This is similar to the behavior that exists today for items inside libraries -- the file dialog defaults to the same directory as the library.
