Under the right set of circumstances, a very useful Right-Click option appears on a broken wire 'Disable Indexing at Source'. I'll wager that many of you have never noticed this option.
If you have an Array Primitive which is wired immediately to an auto-indexing tunnel resulting in a broken wire, you can right click the broken wire:
Not bad, but in this case you are right there to right click on the tunnel anyway. If the autoindexed tunnel is one loop out, no luck. If it is a subVI with an array input instead of a primitive, no luck.
I would like the following improvement to this potentially useful option: Make it work on any wire (broken or not) that has an autoindexed tunnel somewhere along the line. If I have 5 nested loops I would like to be able to move to a wire 3 loops in, choose this option and have all autoindexing removed from that loop outward. No more hopscotch, just one simple step when I want my array to be an array inside a few loops.
Right now I often drop While Loops and then change to For Loops after wiring, that just seems silly.
