13 | |
11 | |
3 | |
3 | |
3 |
Single control items have "NewVal" and "OldVal" in the Data Node for Value Change events. This is applies for numeric, boolean, and strings. It would be nice if this feature were included for listbox and multicolumn listbox labels for the "Edit Cell" events.
Use case: I use a listbox to show the materials for which the user has defined experiment settings for. These settings are saved in an XML file with the material name as an attribute. In the event that the user wants to edit the name in the listbox, it would be nice if they could just do that directly in the list box and the XML change will be handled automatically in the background. Currently to find the right element in the XML, I use an XPath to search for the label selected from the listbox. If the user edits the name, I need to know the old value in order to replace the existing name. Presently, this does not work as the Event Data Node only supplies me with the new value.
