What do you mean by "into a line"? Are you referring to a wire? QuickDrop can already do this. Crtl+Space to open QuickDrop, type in the name of the VI you want to put in, and then Ctrl+i to insert.
There are only two ways to tell somebody thanks: Kudos and Marked Solutions Unofficial Forum Rules and Guidelines "Not that we are sufficient in ourselves to claim anything as coming from us, but our sufficiency is from God" - 2 Corinthians 3:5
It would be useful to insert a VI directly from a project or from a class into a line.
Do you mean any user VI in the project? That would be nice because "Insert -> All Palettes -> Select a VI..." is a long journey and can lead to wrong VIs. Could be a palette called "Project" close to "Select a VI" where that VI's would appear in alphabetical order. For that I will give kudos, but I guess could not be implemented in current LabVIEW due to the way that the palettes are built. Maybe in NXG...
If you find it in the project, you know the name. So I still don't see why QuickDrop is not an option.
Let the user choose which one is better for him. I use both, sometimes it's easier and faster get it from the functions palette, sometimes the drop down is better.
To Manzolli: Thats what i want. "Insert -> All Palettes-> ..." is too far away. I want to have "Insert -> From Project" and "Insert -> From Class". And the view schould be like in the project explorer.
To crossrulz: I dont want to change to the project explorer to get the name so i can use QuickDrop.
p.s.: It's the same with "Insert->Cluster, Cl..->Variant->To Variant". Or is there a better way to insert "To Variant" -> ok, Quick Drop.
where all the other community plug-ins are archived (including some written by NI folks that are nice-to-have but not shipping with LabVIEW for various reasons).
