| User | Kudos |
| 2 | |
| 1 | |
| 1 | |
| 1 | |
| 1 |
Why don't I have the option to add row headers to a single column listbox? I can add a column header - and there is only one column. It is often very helpful to show the row number in a listbox and there is no easy/good way to do this for a single column listbox
