8 | |
6 | |
4 | |
3 | |
2 |
This is so obvious that it must have been addressed before, so my apologies to those who must have seen this suggestion in the past!
The Event structure is only specific down to the "Menu Selection (User)" level. This is certainly useful, particularly if several VIs share common menu items, as this event handler can just call a generic subVI to handle them.
In many of my own designs though, some of the Menu events will duplicate the functionality of front panel buttons (for example: a "Do Something" menu selection, plus a "Do Something" button that does the same thing). It would be useful to have a more specific user menu selection event - in this case, one which trapped the "Do Something" menu selection. Ideally, the general "Menu Selection (User)" event should filter out items which already have specific handlers assigned to them.
Expanding a bit, it would be useful for this event case to also handle the "Do Something" button press. In LabVIEW 2011, if I add a button handler event to an event case which already handles a user menu selection, I lose the ability to select an "ItemTag" in that event case. So now I have to factor the event handing code into a subVI in order to avoid code duplication, which may be inappropriate granularity for simple handlers.
Again, my apologies in advance for suggesting the obvious!
