10 | |
3 | |
2 | |
2 | |
2 |
In Unity (and also Blender I think, probably others) it is possible to adjust a numeric value by giving focus to the field and then dragging the mouse left or right. It works wonderfully.
Take a look at the video, it is pretty self explanatory. The nice thing is that when your cursor gets to the end of the screen it wraps around automatically (even if you have multiple monitors). It really works very well.
In LabVIEW it is not really possible to nicely scroll through a range of values of a control (at edit time or run time). This is the kind of thing that if you have never used it probably does not seem relevant. However it really does work nicely.
