ctenders
Case structure: easier selection for structures with a large number of cases
Status: New
6 Comments
crossrulz
Knight of NI
Right-click on the Case Structure and there is an option to "Show Case".  This will open a pop up similar to QuickDrop allowing you to choose the case you want.  It is there at least in 2019.
ctenders
Right-click on the Case Structure with option "Show Case" shows a similar view as a direct click on the selector label. If the number of cases is high, you have to scroll.
crossrulz
Knight of NI
Not quite.  It is similar to QuickDrop so you can type in the case you are looking for and it will filter the options for you.
NickNZ
I would like the case structure to handle items with a dot notation into a menu (and enums for that matter). I don't think this will conflict with the 10..20 range dot notation as this requires two dots.
So could have an enum
0 Init.step1
1 Init.step2
2 Init.step3
3 Event.button1
4 Event.button2
5 Run
6 Stop
When selecting the enum items it can be configured to "parse items as submenu" rather than a list.
And this can flow through to the case structure to enable handle dot notation as well.
So enum above wired into the case structure turns into a submenu with
init     > Step1
             Step2
             Step3
Event > button1
              button2
Run
Stop
In use case above an auto-group function would be useful.
So would have
808_ > 8080
            8081
            808F
807F
808_ > 8080
Question is how to auto break up the list - could be a bit tricky?
If the enum has
7 Init.Step4 defined later, it should also be grouped with the other "Init" steps.
Can the code from here be leveraged?  - By grouping controls carefully (& some caveats) with the dot notation on FPGA it allows for a submenu.
https://forums.ni.com/t5/LabVIEW/Group-FPGA-Controls-With-Dot-Naming/td-p/2767678?profile.language=e...
This post generated this idea which is the same problem in the FPGA space... grouping long lists to make them easier to use.
https://forums.ni.com/t5/LabVIEW-FPGA-Idea-Exchange/Better-FPGA-FP-Control-Selection/idi-p/3074718
AristosQueue (NI)
NI Employee (retired)
NickNZ: Can you turn your post into a new Idea entry? It's related-but-independent of this idea since even a dotted list could conceivably have long sections, and such a change would probably affect the enum ring itself.
NickNZ
