3 | |
3 | |
2 | |
2 | |
1 |
when I have to rework a vi, i usually start by putting the existing code in a disable structure
and then start working in the disabled 'case'.
Quite often I end up trying to replace the disable structure with a case structure to test the new or reworked vi.
Now I have to copy everyting into a temporary vi, remove the disable structure, put a case structure in place, paste again and rewire iputs and outputs.
Please add the ability to replace the disable structure with a case structure.
