InfiniteNothing
Add the "resize objects" tools to the block diagram
Status: New
When you have a cluster constant and you want to make the elements the same size, it would be nice if you just selected them and set them to the max or the min width.
CLED (2016)
9 Comments
RavensFan
Knight of NI
This already exists.
You can select the items in the cluster and use the Maximum Width button on the toobarl.  (It is under the 3rd button of the group.)  It will resize all the selected elements to the width of the widest element.
crossrulz
Knight of NI
Ravens - this does not currently exist on the block diagram (at least as of 2010 SP1), hence the idea
RavensFan
Knight of NI
Yes, you're right.  I missed the part about the block diagram and was looking at a cluster on the front panel since that is usually where I would care more about the sizing of the elements.
josborne
Active Participant
Kudos!
I was just going to add this suggestion.  But you beat me to it.
I often add parallel loops and parallel case structures, etc, to my diagram.  It'd be nice to be able to resize them so they match.  This will keeps your diagram neat and easy to read.
http://www.medicollector.com
Lefty469
I have to tell you, the incredible small size, and the shortsightedness of not being able to resize the objects, is annoying.
RavensFan
Knight of NI
Then click on the Kudo button to register your vote which is what NI looks at for idea popularity.  Just commenting that something is annoying doesn't do anything.
ncm
I was  going to post this as well but found this on the idea exchange when I Googled this.  RavensFan - I clicked Kudos as you suggested above to register my vote, but have another question.  Will this post be looked at since the original idea was started so long ago?  I am not familiar with the general workings of idea exchange.
-ncm
AristosQueue (NI)
NI Employee (retired)
ncm: All the ideas that are left open are still possible to implement, and, yes, we do get around to ideas that are a decade old. The LV dev team is a lot smaller than most users estimate, and often ideas wait until there are many ideas clustered around the same area to get implemented. Or they get a big kick of kudos and become a priority. Or some developer on the team realizes that he/she can do it without as much effort as previously thought.
I wouldn't hold out hope for this one ever being a reality. It's a nice-to-have from time-to-time, but my personal evaluation is that it would enable some diagram cleanliness, but it wouldn't add any new language capability, and therefore the dev time required is more extensive than the return on investment, especially given the low number of kudos.
ncm
Thank you so much for answering!  This was good information on how new ideas are implemented.  Definitely a bummer that its not a function but understand about the time vs reward aspect.  I will try and get all my fellow LabVIEW coders that are as OCD as I am to give kudos if they like this idea as well. Smiley LOL
Thanks again for the information!
-ncm
