8 | |
6 | |
5 | |
4 | |
4 |
Hi all,
To create a queue, the user would need to use obtain queue, which requires a element data type. Usually, enqueue follows right after obtain queue, and it needs the same data. A bad looking wire bend is created, since there is no data output on obtain queue.
If obtain queue has a feed through output terminal for data data type, the block diagram look nicer.
Any idea that has received less than 7 kudos within 7 years after posting will be automatically declined.
