SteenSchmidt
All VIs In Memory property should return clones as well
I propose that the 'All VIs In Memory' Application property should return all top-level clone instances of reentrant VIs as well.
Currently there is no built-in way to investigate which dynamic clones are running, only static ones.
Basically I want to be able to get the fully qualified names of dynamic clones so I can open references to them, short of having to guess their names. I understand that there is some risk involved in opening a reference which isn't the This reference to a clone, but sometimes that risk is worth it during debugging when you have some rogue clone that is running top-level. And if we want to mitigate that risk you could always vote for this idea as well.
Cheers,
Steen
CLA, CTA, CLED & LabVIEW Champion
4 Comments
fabric
Active Participant
Big fat kudos.
A more sensible implementation would probably be to add a second method called "All VIs And Clones In Memory". I doubt we want to modify the existing method...
PNR
I vote for this idea, since clones should somehow be visible for debugging purposes, however I don't think the 'All VIs In Memory' is the right place for it. A clone is not a VI itself, but rather an instance of that VI. Therefore I would like to see an 'All VI Instances in Memory' property in addition to the 'All VIs In Memory'.
tst
Knight of NI Knight of NI
Knight of NI
Darren
Proven Zealot
