| User | Kudos |
| 10 | |
| 6 | |
| 5 | |
| 3 | |
| 2 |
The "Array to Cluster" primitive should allow you to pass in a cluster type. This allows the output of the primitive to know the names of the elements, as well as how many there are. If the cluster type is wired, you would not need to specify Cluster Size.
