The default Data Directory path is set to "%Userprofile%\Documents" under windows.
This is fine regarding custom probes, settings etc, but problematic when it comes to the compile cache and other "runtime" files.
In our corporate setting, this folder is always synced with onedrive AND with the roaming profile. So one problem is, that it bloats the synced volume, which by it self is annoying. But it often leads to corrupt files when onedrive blocks them or writes them in the wrong moment.
So our workaround is to set this path to %programdata%\LabView Data. This, however, brings new problems, since now all users need write access to this folder.
I think a better way would be to save the folder under %localappdata%, but this can not be done with a symblic path and must be defined static, so it works just for one user.
Solution:
Provide a symbolic link to the %useroprofile% or %localappdata% folders. Additionally it would be nice, if the cache target folder could be seperately defined.
