| User | Kudos |
| 2 | |
| 2 | |
| 2 | |
| 1 | |
| 1 |
Currently, the Deploy Library Invoke Node and DSC Deploy Libraries vi will only work with bound libraries that have a PSP based URL. (\\192.168.0.2\process\variable) But there are some use cases where you need to have logical URL's (\\cRIO1\process\variable) that will adapt to changes in the .alias file which maps target names to IP addresses. If this is your use case then it is tedious to do the same thing programmatically since you will have to create your bound libraries with an initial default PSP URL and then programatically modify all URL's based on a 'designated' target IP. Since the project can do this I assume that it should be relatively easy to provide this functionality.
