This is an excellent feature for populating a new cluster that I use everyday:
This is a feature that needs to be added:
Stipulation: if several constants are highlighted, and they are the same datatype, then allow them to be dropped into an empty array; else, disallow dropping. This will determine the datatype of the array, and initialize the first n items that you dropped in.
