| User | Kudos |
| 12 | |
| 10 | |
| 6 | |
| 5 | |
| 4 |
If you have a log graph that has a range from 10 to 1000 there is only one label (100) between the min and max.
I have found this to be confusing for the end user since the minor increments change from 10 to 100, having labels would clarify the data for them.
