6 | |
2 | |
2 | |
1 | |
1 |
Currently, the only way to add a webservice to a project, is by right clicking a Target and selecting New->Web Service.
There's no way to add existing Web Service definitions to a project, other than manually performing the copy operation at the XML file level.
This prevents proper re-use of IP!
I would propose extending the capabilities of a Library to also support Web Service definitions as Child objects.
That way, the library can act as a container for the Web Service definition, and can easily be reused in other projects:
I tried using an XML editor to manually put a Web Service definition underneath a Library, LabVIEW didn't like that!
