salihgulsen
Network Shared Variable Enable Aliasing Property
Status: Declined
What is needed :
A direct property to change the "Enable Aliasing" option (var_params.png). "Use binding" property only allows to user to change it after enable + deploy the shared variable with "Enable Aliasing" option manually checked once.
Problem in detail:
When a shared variable is created in a local library file, it is needed to check the "Enable Aliasing" checkbox manually once to connect to an URL of a remote tag / psp URL.
After that, Enable aliasing parameter can be changed from the program via the parameter "Use binding". If an attempt to connect the variable to an URL is made with "Enable Aliasing" is not changed manually once beforehand, "A value is missing for the Enable Aliasing option" (missenable.png) or "Missing access type" errors occur (mat.png).
Why is it needed for :
Lack of this property permits the user to create shared variables with an URL connection in a Labview program . You need to create and check "Enable aliasing" manually once each time you need to create a shared variable.
1 Comment
Darren
Proven Zealot
Status changed to: Declined
