The current implementation for remote debugging needs two ports to be opened on a stand-alone firewall in between.
This dynamic port cannot be pre-configured on the stand-alone firewall except by opening up the whole port rang above 1024.
The latter is something no IT person with any sense of security will do !
So we need to be able to pre-configure a certain port for the target application, so that we can open a dedicated port for this connection on the firewall as well.
Otherwise this whole remote debugging feature is useless to many companies.
There have been multiple cases in the last few years where customers (huge ones) have come across this issue.
