8 | |
5 | |
4 | |
3 | |
3 |
Allow a multi-line Format String, with Format Into String treating new lines as though \n was in Format String. Here's an example, where the output appears as three separate lines (and the Format String also looks like three separate lines, shown on the left, with the "correct" and only "legal" way to do this shown on the right).
Not realizing this would be a problem, I just created an 11-line "content" for an INI-like file, not expecting it would "reformat" itself as a line containing 198 characters ... Oops.
Bob Schor
The function should work as intended when input values are wired to Format Into String.
