Fbaird
LabVIEW preferences import/export function
Status: Already Implemented
Functionality is already available. You can copy your LabVIEW INI file between installations to preserve settings.
I would like to propose the idea to have a way to save your labview development environment settings from one version of labview to the next.  I find it a bit tiresome to have to configure labview the way I like it everytime I get the updates (twice a year if you have a service subscription).  Having to toggle to grid snaps and changing the front panel controls icons.  I find its hard to remeber which settings you changed.  I would be nice if those preferences could be exported to a file then imported into the latest version so that you can more seamlessly update your development environment.
5 Comments
AristosQueue (NI)
NI Employee (retired)
Darren
Proven Zealot
Status changed to: Already Implemented
Fbaird
Sweet Mother of Pearl,  That's fantastic.  It even populates the load screen with the last project and VI's I was working on.
crossrulz
Knight of NI
Yep.  Been doing this for a long time.  Just be aware of any sample projects in the pinned and recent since they will likely be pointing to the old version of LabVIEW.  Not likely what you want.  I maually edit the ini file to search for the LabVIEW version (for example: "2015") and replace it with the new version.
_TestMan_
Options\Import-Export would be the correct way to implement this rather than copying the ini file.
