10 | |
3 | |
2 | |
2 | |
2 |
With increasing support for PPLs it would be great to have them be a valid <foundvi> location.
It becomes most evident when refactoring a .lvlib into a .lvlibp.
In cases where we replace "LibraryX.lvlib" with its compiled version of "LibraryX.lvlibp", we easily end up with some VIs that referenced subVIs from the original LibraryX.lvlib that need now to be updated to refer to the versions in the .lvlibp instead.
However, even after manually locating (and selecting) the first "missing" VI from inside the LibraryX.lvlibp , it does not behave as a "conventional" folder would: listed in the default search paths under the <foundvi> category and saving us the trouble of selecting every other "missing" subVI from LibraryX.
To be fair, the workaround exists in having the original LibraryX.lvlib present and replacing it with the PPL version for all projects that use it, but it strikes me as one that could be avoided.
Please let me know if that made sense and I'll do my best to clarify it,
Thanks all,
Cris
