11 | |
7 | |
3 | |
3 | |
2 |
Currently Templates are not allowed in the Tools Menu, at the moment they just get ignored.
A fast way to access Templates would be just to select them from the Tools Menu.
Selecting a Template from the Tools Menu would create a new instance in memory.
See here and here for side chatter.
