13 | |
11 | |
3 | |
3 | |
2 |
At my current work place we use proxy servers as an internet connection. With LabVIEW it makes it difficult not only while the NI software is being installed (to check for updates, connect with server for veryfication etc) but also during typical work it makes troubles with finding examples and drivers from a development enviroment.
I would suggest adding some advenced internet connection options for proxy settings etc.
Another little thing with a company computers is that, even when installing NI software on a D drive it still installs some example software on C:. It makes problem when your IT limited your C drive for absolute minimum, because with huge amount of NI software the amound of "additional" data is getting bigger and bigger.
PacHOOk
Any idea that has received less than 6 kudos within 6 years after posting will be automatically declined.
