13 | |
11 | |
3 | |
3 | |
3 |
Boolean operations support booleans (of course!) and integers. In the case of integers, the operations are performed bitwise.
After reading this discussion, I propose that strings should also be supported as inputs for boolean logic operations, in which case the operation would also be bitwise.
Is there any scenario where this would be a problem?
