6 | |
5 | |
2 | |
2 | |
2 |
Although it might be tricky to implement I would like to suggest the option to add comments to a block diagram while the code is running.
This way you can make notes to the block diagram for debugging and/or "reverse engineering" (examining LabVIEW spaghetti for example).
