Say I paste a function down inside some structure, say a case structure. I wire from the input of the function back to the left hand border of the structure, which creates a tunnel with a 'broken' (dashed) wire to the function.
I would like to be able to right click on the tunnel and hit 'create control' and have it work. Although the wire is dashed, there's no ambiguity about the correct control type as it needs to be the same as the function input.
