HI
When I use event structure
and I have quite lot of cases
adding new case causes I have to connect all input and output terminals
which doesn't change in that case.
The idea to is add a functionality to wire between input and output terminal
inside the event (and case) structure to "autowire in all cases".
In example I dont need to connect the wire in all cases but I eventually need
to disconect the wire in one of them.
It is important for references and other signals which can't be unwired and left with default values .
Available with the Linked Tunnels feature
