A minor niggle I have is the way LV reacts when we resize windows. The anchor point is always at the top-left of the window.
If I grab the top of a window and make it smaller, I don't get rid of space at the top of the window as expected but rather at the bottom. This makes alighning the top of the window a painstaking process of resize, adjust, chack, resize, adjust, check..... I'd live for LV to anchor at the opposite side of wwhere I'm resizing. If I want to resize the panel shown below to get rid of the space at the top of the panel I insitinctively grab the upper windo edge and resize. But alas, the result is not what I expect (Even after 10 years of LV programming).
I want to get rid of the space at the top.....
Doh! Grabbing the top edge doesn't do what I want!
Shane.
