Currently, labels of controls and indicators on the front panel can not be highlighted or copied to the clipboard while the VI is running. This is also true for stand alone labels on the front panel. It would be nice if you could highlight these labels and copy them to your clipboard.
Also, when the VI is not running, after selecting the text of a label, you can not right click and copy. This is also true for cut and paste. However, you can use the copy, paste, and cut windows shortcut keys to be able to perform these actions.
