10 | |
3 | |
2 | |
2 | |
2 |
I know you can mix fonts on a string control but I would like to mix fonts
on boolean text. Example: When the button is false, is says "OFF" in font
25. When the boolean is true it says "ON 23" with "ON" in font 25 but the
"23" in font 12.
