Most items that can be placed on the block diagram allow for access to their owning palette when right clicking. Many even have a second option that is related
this is very helpful - especially when the palette is three or four levels deep. The problem is that not every item has this option. I contend it should. Please allow access to the owning palette of each item as well as the parent palette.
