Almost everything else from the Modern I/O palette has gotten a Silver version, but not IMAQdx session. Even the older, nearly retired IMAQ session has a Silver counterpart. It makes it difficult to present a cohesive UI. I guess the same would apply for whatever else is missing so please add anything else in the comments.
