In many cases I need to use Empty String/Path array constants (Example: Initializing a shift register) but creating a normal String or Path is not readable on top whether anything prresent in the array constant. So it would make more sense to have an Empty Array and String constants available from the function palette. This can be created by pulling an Empty array and dragging the Empty String/Empty Path constants. In this case the Index and scroll bar selections from the view menu may be disabled.
The same can be extended to the other 2D array and further dimensions, which may be given polymorphic behaviour when wired to the respective dimension array.
