This is really just a small time-and-space-saver...
It would be nice if the * Array Elements functions found in the Numeric and Boolean palettes would work directly on clusters:
Yes, the names would probably need to be changed ... but on the positive side, these functions do not even reside in the Array palette!! (Maybe they were destined for better polymorphism from the start
It would be an added bonus if Darin's complementary idea was implemented at the same time.
