The most common way to represent a polar graph is to place the values of the magnitude scale on the lines of the rotary axes instead of on lines emerging from the graph. For example to create a polar antenna radiation pattern.
Currently only shows the values of 0 º, 90 º, 180 º, 270 º. Should be able to set the angle to show, for example every 5 º.There is no possibility to scale the chart, and the value of the axis (magnitude vs. angle). Also growing charts on-line (by adding new points dynamically) is not possible or is extremely slow because it is a control chart based on images pixel by pixel.
In summary ... a Polar Plot.vi with the same properties as XY Graph or Waveform Chart or Graph.
