Many times data is generated or transformed using a function or vi with a single output. In those cases the wire name is the one given by the function or VI terminal, but it would far more descriptive if the wire could have a proper name according to is usage in the block diagram. You can attach labels to wires but these are not propagated particularly when used in places like "bundle" or in structures (for, while, etc.). In large diagrams thus it can be difficult sometimes to now what a wire is for.
This idea proposes to enable the override of the default name of the wire connected to output terminal to that of the label of the function, in case the label is not empty, for single output function or VI. In a similar fashion to the propagation of labels of constants. This could be automatic (not empty label) or deliberate (for instance, using a tick box in the properties page)
This is different from idea Allow-Wire-Labels-to-Dictate-Name-Inheritance-in-Bundles in that it follows the current LabView behavior of the wire name being dependent on labels on constants, and avoids possible conflicts.
