Mads
Label to Object (Quick Change) upgrade to Object/Label to Object/Label
Status: New
If we type up a list in a text label we can now (since LabVIEW 2023) right-click on it, select quick change and convert it to a number of different objects (array, enum, boolean etc)...Once you have done however, right-clicking on the result does not offer the quick change option anymore.
It would be nice and feel more consistent if the same option was available when right-clicking on the supported objects as well; allowing us to convert those to any of the other options and/or even back to the original list (which would allow you to then edit that list efficiently and then reconvert it). Basically an label/object to object/label quick change, instead of just label to object.
PS. I know there are various quick drop plugins that do parts of this, but this would extend the now in-built function to cover those and more scenarios...
