8 | |
3 | |
3 | |
2 | |
2 |
Allow tables, list boxes, etc to be able to lock the right hand column. Currently if you resize a table or list box (or any control/indicator with columns) you end up seeing more columns. It would be nice to be able to lock the right coumn so no additional columns are displayed. Most instances of tables have a defined set of columns which will be used and it looks rather ugly to resize and end up with empty columns. The current alternative is to have code running that will do this programmatically which is a bit cumbersome. Effectively this is allowing the programmer to set a maximum number of columns.
