6 | |
5 | |
2 | |
2 | |
2 |
When replacing a normal Add (of a Timestamp and a value) with the compound arithmetic, the Timestamp input gets broken, this should not be the case.
Any idea that has received less than 7 kudos within 7 years after posting will be automatically declined.
