There is a need to have the capabilities to make comment about a type def/strict type def control (in the control editor) that are only visible in the control editor.
For instance you might want to point to the person editing the control that he/she should not rename that particular cluster element or this will brake the code (and you may want to use an arrow pointing to the element along with some text).
Currently, if you do that the comment become part of the control and is visible for every front panel instance. This bring absolutely nothing to be able to see that type of comment on the FP and it should not be seen by the user of the control (because this actually make the type def so large an unwieldy).
Therefore, there should be a need to select a group of decorations and mark them has only visible in the control editor .
Note: Right now the only way to achieve something similar to what I describe, is to put the comment in the control description, but this is no great because:
PJM
