| User | Kudos |
| 11 | |
| 10 | |
| 6 | |
| 5 | |
| 4 |
I find the color of the Reorder Button on the front panel a little confusing. The colors of the two circular arrows being gray gives me the impression that the buttons is disabled for some reason, especially considering the related buttons to the left have some color with green and yellow boxes. It causes me a slight mental block every time I want to use it. I would suggest that the Reorder button be given some color, such as green, so that it mentally gives the impression that it is allowed to be pressed.
Available in LabVIEW 2011 and later. The 'Reorder' button on the toolbar is now in color.
