I often have a dozen or more simlar controls or indicators (e.g. setpoints for controllers) on a frontpanel that I want to treat in a similar way. For that I create a reference for each control or indicator and then bundle those to an array.
What I would like is that those similar controls or indicators would actually be an array even if its elements would be placed on the front panel as scalars. During development the elements of the array would show up as being elements of an array if you work on one of jhe elements. The big benefit would be that there is only one terminal for all similar scalars.
