2 | |
1 | |
1 | |
1 | |
1 |
Currently, I have to move each of the control into the cluster, and then I have to spend a lot of time repairing the broken wires in the BD.
Is it possible to just select all the controls you need to bundle into the cluster and create a new cluster.
Labview will need to automatically repair those broken wires.
This should work in both BD and FP.
It's just like selecting many stuff on the BD and create SubVI!!
