ipg
Fehler 1052 Library NITASK.LLB beinhaltet VI mit ? im Namen, dies ist nicht zulässig bei der Erstellung von QuellCodePaketen
Status: Declined
Request for support. Pushed to forums.
Soweit ich im Internet nachgesehen habe, existiert das Problem nicht nur in oben genannter LLB
4 Comments
EricC.
Active Participant
Was ist "QuellCodePaketen" in english ?
main deutch is fiel zu alt, konnen sie ales in english sagen ?
Ingénieur d'Application / Développeur LabVIEW Certifié (CLD)
Application Engineer / LabVIEW Certified Developer (CLD)
ipg
Hello i try to translate:
I use Labview 8.6.1, but this problem is still alive in 2010.
I have tried to create a Source-Code-package (in German Version it is called :Quellcodepaket). By this operation
the NI-CAN-Libray (NITASK.LLB) should also be copied. This operation is impossible on windows operation systems, because in this LLB is integrated the vi called "CAN Get Message ID is Extended?.vi". The name of the vi contains "?" this is not allowed in this context.
Therefore Labview calls an error 1052. (Labview-Filename is not allowed).
Unfortunatly is this not the only standard LLB from NI which has this problem.
RavensFan
Knight of NI
This board is for suggesting new ideas on how to improve LabVIEW.  But you have an ordinary LabVIEW question.  You need to post that in the LabVIEW board.
G-Money
NI Employee (retired)
Status changed to: Declined
