| User | Kudos |
| 13 | |
| 12 | |
| 9 | |
| 5 | |
| 4 |
Over the years I’ve created a lot of LabVIEW DLL’s for various projects and use DLL’s for different reasons. It took me awhile to figure out why some of my applications were jerky and sluggish. The reason was the DLL’s were running in the UI thread. After changing the thread setting to run in any thread my problems went away. I found in the literature that when the DLL’s runs in any thread it runs in the calling VI’s thread. Is there a reason the default thread is the UI? I would like to see the default thread be changed to “Run in any thread”.
